TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT
Poster un nouveau sujet   Répondre au sujet    Bac Tunisie Algorithmique et programmation : BAC INFORMATIQUE En Tunisie forum informatique Tunisie Index du Forum -> ::: Divers sujets:: -> Logiçiél portable
Posté le: Mer 31 Déc - 11:38 (2008)    Sujet du message: TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT Répondre en citant
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
*#06# IMEI code
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# **** melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
SAMSUNG T100 SECRET CODES
*#06# -> Show IMEI
*#9999# -> Show Software Version
*#0001# -> Show Serial Parameters
*2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)
*2767*2878# -> Custom EEEPROM Reset
*#8999*228# -> Battery status (capacity, voltage, temperature)
*#8999*246# -> Program status
*#8999*289# -> Change Alarm Buzzer Frequency
*#8999*324# -> Debug screens
*#8999*364# -> Watchdog
*#8999*377# -> EEPROM Error Stack
*#8999*427# -> Trace Watchdog
*#8999*523# -> Change LCD contrast
*#8999*544# -> Jig detect
*#8999*636# -> Memory status
*#8999*746# -> SIM File Size
*#8999*778# -> SIM Service Table
*#8999*785# -> RTK (Run Time Kernel) errors
*#8999*786# -> Run, Last UP, Last DOWN
*#8999*837# -> Software Version
*#8999*842# -> Test Vibrator
*#8999*862# -> Vocoder Reg
*#8999*872# -> Diag
*#8999*947# -> Reset On Fatal Error
*#8999*999# -> Last/Chk
*#8999*9266# -> Yann debug screen (=Debug Screens?)
*#8999*9999# -> Software version
v200 Unlock Code-> *2767*7822573738#
*#9324# Netmon (press the hangup key to exit)
*#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
*#9998*Help# Help screen/ List of codes
*#9998*LOGO# Change operator Logo
*#9998*RTC# RTC Display
*#9998*Bat# Battery Status
*#9998*Buz# Turns Buzzer ON
*#9998*Vib# Turns Vibrator ON
*#9998*LCD# LCD Contrast
*#9998*9999# Softwre Version
*#9998*377# NVM Error Log (?????)
*#9998*NET# SIM Network ID
*#9998*778# SIM Serv. Table
*#9998*SIM# SIM Info
*#9998*PN# Production No.
*#9998*968# Reminder Tune
*#9998*NVM# Displays Non-Volitile Memory Status
*#9999*C# ???????????????????
*#06# Displays phones I**I No.
***/// ***/// NOTE /// *** RED COLOR , they appear serious !!! Use at
own risk !!!
*#9998*2576# Forces SIM Error
*#9998*DEAD# Forces Phone Crash
*2767*MEDIA# Resets the medis on the phone (deletes all downloaded
pics/tones)
*2767*FULL# Resets the EEPRON *DANGEROUS*
*2767*CUST# Resets the Custom EEPRON
*2767*JAVA# Resets JAV downloads (deletes all downloaded midlits)
*2767*STACKRESET# Resets Stack
*2767*225RESET# ????????????????? * Dangerous *
*2767*WAP# Resets WAP Setting & Deletes Favorites
The universal unlock code is *2767*637# do this with out your sim in
By default, the firmware (software) for x600 only receives java
apps and other applications like stuff by serial port.
but even for it, you have to enable the serial port, which also
causes
the closing of all other ports, even the IrDA too )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... )
the master reset code is:
#*7728#
I take no responsibility of these codes are working or not,
or its effects on your cell fone
but i have tried these codes on my cell fone.
and i bet, nothing goes wrong,
but even then of my words, be carefull!,
The code: *#8999*8378#
as i regarded it a informative code,
will tell you each and everything about your cell fone.
and in the "H/W test",
there are lot of other Audio settings,
each of them having five (5) levels,
you can change the combination, but before doing anything,
do write the defult number sequence to some place so that
you'll be then able to invert it again! .. FPRIVATE "TYPE=PICT;ALT=Smile" ...
#*2558# - Time ON
#*2527# - GPRS Switching Set to class {4/8/9/10}
#*4263# - Handsfree Mode: ACTIVATED
#*53696# - [Java dnload] WAPSAR mode
#*536961# - WAPSAR enable HTTP disable
#*536962# - HTTP enable WAPSAR disable
#*536963# - SERIAL enable Others disable
#*5663351# - [Phone Model] SAMSUNG SGH-X100
#*6420# - Mic off
#*6421# - Mic on
#*7632# - Sleep mode
*#8999*523# - Main LCD Brightness
*#8999*3825523# - (?) External display
*2767*3855# - Full EEPROM reset(Reset all type of locks)also you'll
lose pictures and java not melody
Remove camera sound:
On main screen type:
*#8999*8378# --> Test mode
H/W test
Audio Settings
Melody Gain
Then replace 6 by 0, it'll show 12 but it's OK
Press back until main screen
Then press key volume to minimum and let's try !!! no more sound
tip by C-Quest
*2767*688# resets the phone
Thats all!!
Samsung X100 Tricks
#*0000#
#*0400#
#*1200# - AFC DAC Val
#*1300# - IMEI
#*1400# - IMSI
#*1700# - ( ) Command #*1700 Executed
#*1800# - ( ) Command #*1800 Executed
#*1900# - ( ) Command #*1900 Executed
#*2000# - ( ) Command #*2000 Executed
#*2100# - ( ) Command #*2100 Executed
#*2200# - ( ) Command #*2200 Executed
#*2252# - Current CAL
#*2255# -
#*2256# - Calibr.-Info
#*2282#
#*2285#
#*2286# - Databattery
#*2337# - ( ) Permanent Registration - Not Yet Implemented
#*2355#
#*2400# - ( ) Command #*2400 Executed
#*2474# - For CMD Set - DEBUGBATTERY in cihard.opt
#*2558# - Time ON
#*2562#
#*2565#
#*2677# - AMR State: {None / Full Rate}
#*2679# - Copycat Feature: {ACTIVATED/DEACTIVATED}
#*2787# - CRTP {ON/OFF}
#*2834# - Audio path Mobile Normal
#*2836# - AVDDSS Management: {DEACTIVATED/ACTIVATED}
#*3230# - Trace Enable DCD disable
#*3231# - Trace disable DCD Enable
#*3232# - Current Mode {Trace enabled/DCD enabled}
#*3270# - DCS Support: {DEACTIVATED/ACTIVATED}
#*3282# - Data: {DEACTIVATED/ACTIVATED}
#*3333#
#*3353# - General Defence Code Erased
#*3370#
#*3377#
#*3476# - EGSM: {DEACTIVATED/ACTIVATED}
#*3676# - Flash Volume Formated
#*3683#
#*3737# - Some Codes
#*3777#
#*3779#
#*3825# - ( ) Command #*3825 Executed
#*3837#
#*3849#
#*3851#
#*3876#
#*3877# - Dump of SPY Trace
#*3900#
#*3940# - External looptest 9600 bps not available in SYSOL2
#*3940# - External looptest 115200 bps not available in SYSOL2
#*3941#
#*4200#
#*4300#
#*4500#
#*4674# - IMSI| MCC:2 5 0 | MNC 9 2 | 10 11 91 83 50
#*4700# - Half Rate: {ACTIVATED/DEACTIVATED}
#*4760# - GSM: {ACTIVATED/DEACTIVATED}
#*4864#
#*5100#
#*5111# - ( ) Some Codes
#*5132#
#*5133# - ( ) Some Codes
#*5143#
#*5156#
#*5165#
#*5171# - ( ) Some Codes
#*5172# - ( ) Some Codes
#*5173# - ( ) Some Codes
#*5174#
#*5175#
#*5176# - ( ) Some Codes
#*5177#
#*5187# - L1C2G trace: {ACTIVATED/DEACTIVATED}
#*5376#
#*5400# - ( ) Command #*5400 Executed
#*5500#
#*5600#
#*566335# - [WAP model ID]
#*5663352# - [Java Model] SEC-SGHS300/1.0
#*5737425# - Java Serial
#*577699# - APN
#*5800# - ( ) Command #*5800 Executed
#*6100# - ( ) Command #*6100 Executed
#*6200#
#*6420# - Mic off
#*6421# - Mic on
#*6422# - Mic dep RXdata
#*6428# - Mic measurement
#*6700#
#*6837# - Official Software Version
#*6900#
#*7200#
#*7222# - Operation Typ: Class C GSM
#*7224# - ERROR
#*7247#
#*7252# - Operation Typ: Class B GPRS
#*7271# - Multi slot: Class 1 GPRS
#*7274# - Multi slot: Class 4 GPRS
#*7276#
#*7284# - Class B
#*7287# - GPRS Attached
#*7288# - GPRS Detached
#*7326# - Accessory: Vibrator
#*7337# - Some kind of Reset Settings
#*7352# - Some Kind of Debug Info
#*7462# - SIM phase
#*7524# - KCGPRS
#*7562# - LOCI GPRS
#*7626#
#*7629#
#*7633#
#*7638# - RLC always open ended TBF: {ACTIVATED/DEACTIVATED}
#*7646#
#*7665#
#*7666# - SrCell Data
#*7673# - Sleep mode
#*7676# - Command #*7676 Executed
#*7683# - Sleep variable
#*7693# - Sleep deact
#*7728# - RSAV done->reset
#*7762# - SMS bearer CS {ACTIVATED/DEACTIVATED}
#*7825#
#*7828# - Midl Rl51
#*7957# - Command #*7957 Executed
#*7983# - Voltage/Freq {DEACTIVATED/ACTIVATED}
#*7986# - Voltage {DEACTIVATED/ACTIVATED}
#*8462# - Sleep time since SwitchOff
#*8465# - Time in L1
#*8466# - Old Time
#*8645#
#*9278# - Command #*9278 Executed
#*9795# - wtls key: reset
#7263867# - RAM Dump {On/Off}
#7465625*228# - Activa lock deactivated
#7465625*27*
#7465625*2827# - Auto CP lock deactivated
#7465625*28638# - Auto Network lock deactivated
#7465625*28746# - Auto SIM lock deactivated
#7465625*2877# - Auto SP lock deactivated
#7465625*28782# - Auto subset lock deactivated
#7465625*638*
#7465625*746*
#7465625*77*
#7465625*782*
#8999*324#
*#0*
*#0020# –
*#06# – IMEI
*#2255# - Call List
*#4777*8665# – GPRS
*#7465625# – Interrogate ( )
*#8377466# – Software && Hardware Versions
*#8888# – Hardware Version
*#8999*324# - ( ) Some Strange Numbers
*#8999*377# -
*#8999*3825523# - ( )
*#8999*636# - ( ) Another Strange Numbers
*#8999*8376263# - . HW, SW, + Some Code And Data
*#8999*8378# - . , , , HW SW
*#9999# – Software Version
*2767*xx927 - WAP . xx - . , xx=44: *2767*44WAP# xx=31: *2767*31WAP#
*2767*xx667 - MMS.
*2767*2877368#
*2767*2878# – EEPROM ( , )
*2767*31667#
*2767*31927#
*2767*33667#
*2767*33927#
*2767*34667#
*2767*34927#
*2767*351667#
*2767*351927#
*2767*3700#
*2767*380667#
*2767*380927#
*2767*3855# - l EEPROM ( SP- !! ) IMEI 447967-89-400044-0, IMEI ( )
*2767*39667#
*2767*39927#
*2767*420667#
*2767*420927#
*2767*43667#
*2767*43927#
*2767*44667#
*2767*44927#
*2767*46667#
*2767*46927#
*2767*49667#
*2767*49927#
*2767*66335#
*2767*688# ( ) [Unlocking Code]
*2767*7100#
*2767*7300#
*2767*73738927# = *2767*RESETWAP#
*2767*7650#
*2767*7667#
*2767*7927#
*2767*8200#
*2767*927#
*335#
*663867# - mm file dumped
*7465625# -
*7465625*228# - Activa lock personalized
*7465625*27*
*7465625*2827# - Auto CP lock activated
*7465625*28638# - Auto Network lock activated
*7465625*28746# - Auto SIM lock activated
*7465625*2877# - Auto SP lock activated
*7465625*28782# - Auto subset lock activated
*7465625*638*
*7465625*746
*7465625*746*
*7465625*77*
*7465625*782*
D500
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
mhd ali
Point(s): 12
Posté le: Sam 7 Nov - 16:06 (2009)    Sujet du message: TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT Répondre en citant
merci bien
chocko
Point(s): 2
Posté le: Jeu 10 Fév - 00:31 (2011)    Sujet du message: TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT Répondre en citant
ces code  ne marache pas avec le samsung u700
  Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Posté le: Jeu 10 Fév - 15:23 (2011)    Sujet du message: TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT Répondre en citant
Codes pour le U700 (Différents pour le U700V / V pour Vodafone)
*#6984125*# Menu "Admin Setting"
     > *#9072641*# MasterKey pour le menu "Internals"
     > *#73561*# : Pre-configuration (Operator code)
*#0523# Menu de Configuration
*#0002*28346# : Affiche par défaut :
There is no loading files.
>If you want to load params,
>>Put files trough TkExp
Appuyez ensuite deux fois sur '#" et ceci devrait apparaitre :
[1] Load Params
[2] Dump Params
[3] Call Config
Pour augmenter le son lors d'appels vocaux :
Taper : *#0002*28346# puis deux fois '#'
Puis vous avez 3 menus :
[1] Load Params
[2] Dump Params
[3] Call Config
Faites 3 puis 1 pour [1] RCV Rx Call Vol[*]
Là vous avez ceci :
0.[2] rx:-12.0dB
1.[4] rx:-11.0dB
2.[6] rx:-10.0dB
3.[8] rx:-9.0dB
4.[10] rx:-5.0dB
5.[12] rx:-1.0dB
6.[14] rx:+3.0dB
Cela correspond au 7 niveau de volume du téléphone donc pour modifier le plus fort :
Taper '6' puis '40' pour 4 decibels
Ma config :
0.[2] rx:-12.0dB
1.[4] rx:-11.0dB
2.[6] rx:-10.0dB
3.[8] rx:-9.0dB
4.[10] rx:-5.0dB
5.[12] rx:3.0dB
6.[14] rx:7.0dB
akm88
Point(s): 3
Posté le: Lun 18 Juil - 05:55 (2011)    Sujet du message: HI!!! Répondre en citant
Fine!!!
It is a good information about samsung secret codes..
I am using Samsung A600 model mobile, it is unlocked, through this site http://www.mobileunlockguide.com/ , it has the step by step instructions for unlocking mobile, then i am searching for the secret code for my another samsung mobile at that time i saw this one & now successfully i got the secret code for my samsung mobile..........Nice work done by you...........
Posté le: Aujourd’hui à 19:09 (2017)    Sujet du message: TOUS LES CODES ET ASTUCES DE SAMSUNG GRATUIT
Poster un nouveau sujet   Répondre au sujet    Bac Tunisie Algorithmique et programmation : BAC INFORMATIQUE En Tunisie forum informatique Tunisie Index du Forum -> ::: Divers sujets:: -> Logiçiél portable Toutes les heures sont au format GMT + 1 Heure
